ip phone doesnt give busy tone for the 2nd calls
when a 2nd call comes to the ip phone(which has already a call), calling person hear ringing tone instead of busy tone. This only happens internal calls.
If i call from outside i mean PSTN , it is ok, it gives busy tone for 2nd calls.
ccm 4.1.3
thkns
Bronze
Re: ip phone doesnt give busy tone for the 2nd calls
hi,
check whether "busy trigger" field on the line is set to "1".
regards
mehmet
Go to the configuration for the Directory Number in CCM Admin. Check the busy trigger setting. If you want the second call to ring busy, this will need to be set to 1.
Hope this helps. If so, please rate the post.
Brandon
180
