ip phone error message "system overload"
Hi All
One of my customer with Cisco IP Phone (6921 series phone ) getting "system Overload" message when pickup the handset. does any know why
this is happening, its woek normal after some time...looked at the sever alerts and found nothing.
ronpatel
Level 8
Level 8
Hi ,
Never seen this message. But would like to check are you using CMEor SRST or CUCM. The message shows that the call control application is busy.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
