Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
IP Phone firmware authentication fail on CME4.0
Problem: IP Phone firmware authentication fail
System:
IOS c2801-advipservicesk9-mz.124-11.T
CME4.0
IP Phone 7961 and 7970
Upgrade procedure:
1. Download cme-DST-phoneloads.zip
2. Extract cme-DST-phoneloads.zip on my hard drive, get four .tar files
CME-7931_8-2-1-DSTFix.tar
cmterm-7906-7911-sccp.804SR2.tar
cmterm-7941-7961-sccp.804SR2.tar
cmterm-7970-7971-sccp.804SR2.tar
3. copy cmterm-7941-7961-sccp.804SR2.tar and cmterm-7970-7971-sccp.804SR2.tar to flash
4. archive tar /xtract .tar files on flash
5. The Configuration on CCME:
globle:
tftp-server flash:jar41sccp.8-0-3-32.sbn
tftp-server flash:cnu41.3-1-3-30.sbn
tftp-server flash:apps41.1-1-3-30.sbn
tftp-server flash:dsp41.1-1-3-30.sbn
tftp-server flash:cvm41sccp.8-0-3-32.sbn
tftp-server flash:SCCP41.8-0-4SR2S.loads
tftp-server flash:jar70sccp.8-0-3-32.sbn
tftp-server flash:cnu70.3-1-3-30.sbn
tftp-server flash:apps70.1-1-3-30.sbn
tftp-server flash:dsp70.1-1-3-30.sbn
tftp-server flash:cvm70sccp.8-0-3-32.sbn
tftp-server flash:SCCP70.8-0-4SR2S.loads
telephone-service:
load 7961 SCCP41.8-0-4SR2S
load 7970 SCCP70.8-0-4SR2S
6. reset IP Phone, upgrade failed. Look up the status messages, it said "file SCCP41.8-0-4SR2S authentication fail"
I used same procedure with other two CME4.1 system, it worked well.
Silver
Re: IP Phone firmware authentication fail on CME4.0
Try resetting the IP Phones and capture the "debug tftp events". That should tell you what the problem is.
i am the same message.
How did you resolve the problem?
Best regards
720
