Community Member
IP Phone function test
With a change of coworkers the telephones are cleaned and disinfected. Is it possible a test to start around to examine all functions is again ready for use?
Re: IP Phone function test
not sure what you want
cleaned and disinfected???????
what functions are you talking about?????
is this for CUCM or CME??
not enough details or info to provide any help with only that
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
if a employes changes or leaves the job. Its IP-Phone will be cleaned. To test that the telephone functional correct we should test display and LED that are functional correct. I would like to start a test scenario
on the Phone. like**#** or something else. Do you have any hotkey.
tx Roland
Hall of Fame Super Silver
Sorry there is no such feature to autmatically test phones for features, your only option is to create a simple test plan and execute it at will. Interesting idea thought :-)
Chris
392
