01-27-2012 01:08 PM - edited 03-16-2019 09:15 AM
I'm seeking informations about the feature of setting an ip phone on a remote location as a firmware distributor for other ip phones in the same location.
Useful for remote location with low bandwidth.
Does anyone ever heard about this ?
Thanks.
Solved! Go to Solution.
01-27-2012 01:11 PM
What phone system, CME or CUCM?
With CUCM you simply turn up Peer Sharing feature on the phones and only one phone on each subnet will download the firmware file from TFTP server and distribute to other phones.
HTH,
Chris
01-27-2012 01:16 PM
Hi Jean-Christophe,
Peer Firmware Sharing will be your friend here
One of the best (if not the best) descriptions is available in this nice
blog from Bill Bell @ Chesapeake Netcraftsmen
Cheers!
Rob
01-27-2012 01:11 PM
HTH,
Chris
01-27-2012 01:18 PM
Sorry, I'm running CUCM.
Ok thanks now I've the words Peer Sharing. So I'll have a look at older posts...
01-27-2012 01:16 PM
Hi Jean-Christophe,
Cheers!
Rob
01-27-2012 01:19 PM
Hi Rob
I was just reading your post https://supportforums.cisco.com/thread/2053090
01-30-2012 01:45 AM
Unfortunately we're using 8945 phones, and they don't have any Peer Sharing parameter in the Product Specific Configuration Layout.
