Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Ip phone is not registering on CME
Hi voice team!!
I did the SRST configuration and work properly in my environment...
But when I turned back the old configuration "CME" all ip phones are dropping packets and it is not registering:
Resposta de 10.100.2.59: bytes=32 tempo=1ms TTL=64
Resposta de 10.100.2.59: bytes=32 tempo<1ms TTL=64
Esgotado o tempo limite do pedido.
Resposta de 10.100.2.67: Host de destino inacessível.
Resposta de 10.100.2.59: bytes=32 tempo=1996ms TTL=64
Resposta de 10.100.2.59: bytes=32 tempo=998ms TTL=64
Resposta de 10.100.2.59: bytes=32 tempo=997ms TTL=64
thanks..
Hall of Fame Super Silver
Delete ITL certificates from the phones.
Chris
Great, but How Can I to do this please?
On the phone go to secuirty setting, on 79XX it is under Settings --> Secuirty --> trust list --> ITL,  unlock the phone (**#), select more softkey and chose Delete.
Chris
293
