Community Member
Ip phone issues -- hospital down
Hi I have some issues with the main ip phones from a hospital
they are un-registered and the display on the phones shows ethernet disconnected
what should I do, if I unplugg the phone from the wall and plug it back in, we have the same issue, do we have a problem with the switch?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Ip phone issues -- hospital down
More likely, you have a problem with cabling somewhere.
Community Member
thank you
I will check the cabling
Thanks for the nice rating and good luck!
Community Member
If you see the Ethernet Disconnected message, it means exactly that. There is no active network connectivity. It could be cabling, but if the phone was working fine before you should check the switch as well to make sure the port the phone is connected to is active. Either someone has been messing with your network cabling, or you have a network switch issue.
145
