IP phone just appear green led on speaker
I guys,
my cisco phone model 7945 wont boot. appear a green led on speaker but dont cross that part...
what is the cause of that problem ? what i need to solve it?
thanks
Everyone's tags (7)
I too have two 7945s that won't boot. Tthey are stuck with a black screen and the speaker button is solid green.
Is there a fix for this?
VIP Purple
Hi ,
Were these working IP phones and what is the call manager version along with existing load ?
Did u try factory reset of IP phone?Please find below URL for doing factory reset
http://cisco-techblog.blogspot.in/2011/05/performing-factory-reset-of-a-cisco.html
regds,
aman
Blue
I believe this is hardware issue. You can have TAC raised and see if RMA can be done for this.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
What does this mean? "You can have TAC raised and see if RMA can be done for this." A factory reset fails.
VIP Super Bronze
It means the phone is dead. If you have SMARTnet maintenance on that serial number Cisco will likely replace it for you. You'll need to open a SR with TAC.
2651
