Ip phone keypad lock/unlock
Does anybody knows how lock/unlock the IP phone keypad to secure the device? Means input 4 digit to lock and 4 digits to unlock the keypad to make outbound calls. Always can receive phone calls. (No after hours pin)
Thanks in advance
Re: Ip phone keypad lock/unlock
Are you in a CUCM or CME environment? In either case, that is something that must be configured on the call controller (either server or router) and not on the phone itself. The feature is called Forced Autherntication Codes.
We are using CME 7.0.1 on 2851 router. Where can I get documentation about Forced Authentication codes?
This will be the best information you'll find on this:
https://www.myciscocommunity.com/docs/DOC-1400#Can_UC500CME_be_configured_to_prompt_a_caller_for_a_PIN_before_placing_a_call
It's not an officially supported feature, but this guide should be sufficient to getting it to work.
hth,
nick
We do not use h323..
Can we not use these commands:
aaa new-model
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
They are written in the example. We use Sccp and do not use radius.
Luis
Bronze
you're probably looking for a 3rd party app to do this for you. there is an app that moves the phone from partition to partition based on the keypad lock code. have not tired it but it seems simple enough.
you (the admin) controls what type of calls can be made when the phone is locked. typically, it would be extension to extension as well as emergency but again you control it.
i have only used this in a lab environment. you might want to contact them to see if they have support for Express.
have a look, http://www.andtek.com/communications-products-lockout.html
this is by no means a recommendation of this software but its just to point you in the direction im thinking you might be looking at.
thanks
Hi all, and with CUCM???? How I can do it?
390
