IP Phone Logo Change
Hi All
Possible to change logo cisco ip phone 8945,8961,9951and 9971 in CME router 2911 series .
Jaime Valencia
Yes, this has been asked hundreds and hundreds of times at CSC, PLEASE, search before you ask
Image specs are here, look for same doc for 8945
Creating Custom Background Images
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cuipph/9971_9951_8961/7_1_3/english/admin/guide/9971cus.html#wp1038500
If you need assistance on doing the procedure on CME, that has also been addressed plenty of times before at CSC, do a quick search and you'll find all you need. Just adjust the image size and folder to any instructions you find.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
