IP Phone Logo - Is it possible apply logo only specific floor
My Customer developed the logo for any IP Phones (79xx), and would like know is possible apply this configuration in the first time only about specific floor. (For example 4 rd floor)
|_______________ | n xx floor
|_______________ |
|_______________ |
|_______________ |
|_______________ |
|_______________ |
|_______________ |
|_______________ | 2 th floor
|_______________ | 1st floor
This environment there are only TFTP server and we use CUCM 8.6.2
Wilson
2 ACCEPTED SOLUTIONS
All the images on the TFTP server are shared, so all phones would have access to the images, unless you deployed multiple TFTP Servers with different images. Also you would have to manually go round all the phones on each floor.
For this requirement I strongly recommend PhoneView from UnifiedFX (http://www.unifiedfx.com), not only can oyu push background images out remotely in bulk, you can filter by a lot of different criteria. In this case you could filter to all the phones connected to the relevant access switches on each floor and then remotely update the corresponding background image.
Kind Regards.
Stephen Welsh
The same you've been told by Carlo and myself on this thread
https://supportforums.cisco.com/thread/2243094?tstart=0
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Kind Regards.
Stephen Welsh
java
java
2Ring PHONE SERVICES dispose with such feature.
In other words, it is possible to specify the group/floor based on extensions (IPs will be added in some of oncoming releases).
Then you are able to send the background picture to this groups within the app GUI. Also, it means that the pictures don't have to be directly at the TFTP server, but must be available at PHONE SERVICES server.
If you are interested in, just follow the link to get more info: http://www.2ring.com/NewJuice
Martin
185
