Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
IP Phone lost there image after upgrading CCME
I recently upgraded my CCME3.3 to 4.0(2)so that i can use the video conferencing features on my CCME. After upgrading CCME and IOS, most of the IP Phones lost there images and displaying an error "Protocol Application Invalid".
So i degrade back my CCME & IOS versions.Then again i loaded back the IP phone images.
What's is the problem? Is it i can able to upgrade CCME without having this problem?
1 REPLY
Hall of Fame Super Gold
Re: IP Phone lost there image after upgrading CCME
Possibly you need to upgrade the IP phone firmware also. What are you using now ?
Download the TAR file with DST fix from CCO. Extract to router flash with
archive tar /xtract
configure each file for download with:
tftp-server flash:/ alias
If your router doesn't support directories (that is, less than 28xx) just use
tftp-server
and load under telephony-service, without the .loads extension
Hope this helps, if so please rate post!
128
