IP phone not able to make incoming and outgoing calls
dears,
need some help in the folowing
while making outgoing calls , hear some kind of disturbance sound
attached debug voice ccapi
Please share your router config with us here.
Re: IP phone not able to make incoming and outgoing calls
Thanks Omer,
here you go
incoming calls are working or not ? what do you mean by disturbance sound ?
Please post outputs of below debugs
debug vpm signal
debug voip dialpeer inout
Please rate if post is useful.
While connecting pstn line with analog phone both incoming and outgoing working
Incoming and outgoing calls not working when pstn is connected to UC520
the sound heard is noise as attached
Hi Edwin,
The called number 90566919592 is matching 7 pots dial-peers(1009-1016) which are pointing to different 7 different FXO ports. Now i guess your analog pstn line is single channel.If you need to test call on this PSTN connection , i would suggest below.
Create a new explicit pots dial-peer and point it to a port on which you have connected your analog PSTN line.
dial-peer voice xxxx pots
corlist outgoing domesticcalls
description "Calls to Mobile carrier - Saudi Arabia"
destination-pattern 90566919592
port 0/3/3
forward-digits 10
no sip-register
Manish
Rate all the helpful post.
Hi manish,
But the call was going through 0/1/0 where the pstn in connected right
So where is the problem ? Is you PSTN link works fine with port 0/1/0 ?
I was going through debug that you shared for called number 90566919592 which is matching destination-pattern 905[0-9]....... and that is not pointed to 0/1/0 port.
Manish Prasad
Dears,
The issue is solved, the whole problem was with the cabinet could be earthing.
we removed the UC520 from the cabinet , the calls are going out and in
just resolved issue by reading the below forum
https://supportforums.cisco.com/thread/99219
thanks everyone for the support
563
