IP phone not getting registered in CME
We have some 5-6 IP phones not getting registered to CME . " Registration failed " is coming to these 5-6 phones .
we have enough licenses . TFTP is reachable .  here are the config i have checked in CME
ip dhcp pool VOICE_VLAN
network 10.1.0.0 255.255.255.0
default-router 10.1.0.1
option 150 ip 10.1.0.1
cnf-file perphone
load 7915-12 B015-1-0-4
load 7915-24 B015-1-0-4
load 7942 SCCP42.9-2-1S
load 7945 SCCP45.9-2-1S
load 7962 SCCP42.9-2-1S
load 8945 SCCP894x.9-1-2-SR-1
Telephony service ----
no auto-reg-ephone
cnf-file perphone
what could be the issue .   Thanks in advance !!!!!
HI Kailash,
Please use the below link,
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/troubleshooting/guide/ts_phreg.pdf
Also make sure to follow th below tips.
-Make sure to have the compatiable phone loads.
-Should have enough ephone dn and numbers.
-Please cross check the exact MAC id entered in the CME for these phones.
-Please do not overlap any ephone, ephone-dn or buttons.
-Do a factory reset of the phones and try once again
Hope it helps.
Anand
Please rate helpful posts by clicking on the stras below the right answers !!
Blue
You aare using "no auto-reg-ephone " under telephony service confguration. It means you will have to add the phones manaually.
Do following configuration.
ephone x
mac address "ip phone Mac address"
reset
Ronak Patel
Please rate helpful posts by clicking on the stars below the right answers !!
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Kailash,
                   Are these phones are the same model? Is ther any reason that you are using the comand "cnf-file perphone" as it generates a separate configuration file for each phone. Instead you can use "cnf-file perphonetype" it generates a
configuration file for each type of phone and then use the command "create-cnf" .
Also if the above doesn't work , let us know if the Phone is getting the IP from the DHCP .
Abdul
Please rate helpful posts !!!
2359
