IP Phone over Site-to-Site VPN dropping at 30 minutes
I have a remote site with an ASA 5505 connecting to my corporate site with an ASA 5520.  When a call is made from the remote site to the corporate site, it is dropped at exactly 30 minutes into the call.  The CUCM cluster that controls both sites is at the corporate site.
Any insite?
Corey,
Verify the lifetime setting under the "crypto isakmp policy" It may bet set to 1800 seconds whic is 30 minutes. Example below:
crypto isakmp policy  30
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
Yosh
HTH Regards, Yosh
Thank you for the reply.  All of the crypto isakmp policies have a lifetime of 86400.  Another thing to add is that even when the call drops at 30 minutes, the VPN tunnel stays active and does not reset.
I am wondering if you are hitting the default timeouts:
h323 hh:mm:ss is 5 minutes (00:05:00).
half-closed hh:mm:ss is 10 minutes (00:10:00).
icmp hh:mm:ss is 2 minutes (00:00:02)
mgcp hh:mm:ss is 5 minutes (00:05:00).
mgcp-pat hh:mm:ss is 5 minutes (00:05:00).
rpc hh:mm:ss is 10 minutes (00:10:00).
sip hh:mm: is 30 minutes (00:30:00).  <-- 30 mintues
ex:
http://www.cisco.com/en/US/docs/security/asa/asa71/command/reference/t_711.html#wp1318629
For testing purpose, adjust the default and see if it does make a difference, if it does then we'll have to figure out next step on why its hitting this when you have an active call.
460
