08-13-2008 09:10 PM - edited 03-15-2019 12:36 PM
My customer is running ccm 3.3 and 7940 ip-phone for China, Vietnam and more offices.
They are running more than 100 ip-phones in the Beijing office.
The Beijing users claim that many 7940s reboot during the business hours some times an week.
I suspect that the power is unstable for the office and I would like to prove it.
What kind of message is supposed to be logged for the PoE switch(Cat3550) or CCM when they have power problem?
Kawakami, Tetsuo
08-14-2008 12:01 PM
For starters you could do a "show ver" on the 3550 to show the uptime. This would determine if the switch is losing power and reloading.
08-14-2008 12:12 PM
You might want to check the CCM Application Log. When the phone unregisters it should log a message with a Reason Code. It will tell you if it's a Device Initiated Reset a CCM reset or a Network connectivity issue.
Check this link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/err_msgs/4_x/alarms41.htm
Hope this helps :)
08-14-2008 05:37 PM
JEFF-san, TERE-san,
It is good help. Thank you for your quick advice. I would inform them these information.
Kawakami,Tetsuo
NCR Japan
