ā08-26-2013 05:33 PM - edited ā03-16-2019 07:03 PM
Hi there,
I got a little bit confuse regarding the phone registration to the CUCM.
Here is the senario.
There are 2 companys, A and B both have CUCM, there is a direct link at company B to A, I brought a phone from company A and plug in, the port I plugin has company A data vlan and company B voice vlan, I manully changed the ip address, default gateway and TFTP server on the phone that point to company A, but the phone can not register to company A's CUCM, it keeps trying to register but failed.
Once I remove the voice vlan on the port, the phone can register without problem.
what confuse me is what does the voice vlan do to prevent the phone register to company A's CUCM.
ā08-26-2013 06:38 PM
What version of CUCM is company A? If 8.0 then read up on security by default, you will need to perform factory reset to get it registered.
On the flip side what is the phone status saying? Is it getting IP address and proper TFTP? Is it defined on cluster B or are you using auto registration?
Chris
ā08-26-2013 06:57 PM
Hi Chris,
Both CUCMs are version 7.
on the phone screen it shows registering, then after a while, it appears again.
I manually defined the ip address and TFTP server and the phone is not configured in cluster B.
I need the phone register to cluster A to do the testing and the phone was registered to cluster A.
Cheers
ā08-26-2013 10:40 PM
You can take a pacp from the switchport where the phone is connected and that pcap will help you check the signalling and figure out why it doesn't register.
Posted by WebUser Asad Raza from Cisco Support Community App
ā08-27-2013 05:57 AM
Check the network reachability from company b voice plan to company A CUCM
Your data vlan is reachable by company A CUCM dats y its registering
plz check and let us know
