IP Phone Rejected on Subscriber
I have an IP Telephony setup with Publisher and Subscriber ver. 9.1.
I created a new Call mager group and have Subscriber higher than my Publisher in my CM group.
Reloaded phones and they re-registered to the Publisher.
For testing the DB replication I have added a end user in subscriber and its reflecting on publisher also.
I checked all the services are up and running in 2 nodes.
I disconnected my Publisher from the network and my phones did not even re-register and its showing in the subscriber as REJECTED.
Earlier i auto registered all the phonoes through publisher and now auto registration is disabled on both the nodes.
Please help to resolve the issue.
Thanks in Advance......
Nithin Louis...
2 ACCEPTED SOLUTIONS
VIP Purple
Re: IP Phone Rejected on Subscriber
Hi Nithin,
from the CLI of SUB, can u ping DHCP server /vice versa and share the output.
did u change hostname to IP address?
regds,
aman
Are the pub and sub separate or are they common on the same VLAN?   Are you using DNS/hostnames in your configs or purely going IP?
Your SCCP phones are failing over properly and only your SIP phones won't reg w/ the sub?
How are your phone VLANs separated from your cluster?   Any firewalls or routers between them?
VIP Purple
Hi Nithin,
Is call Manager service running on SUB?
Can u share the output of show utils dbreplication runtime state and show network eth0 details from Pub/SUB ?
regds,
aman
Hi Aman,
Thanks for reply.
Call Manager services running on Publisher only.
I have created a test Call Manager group for checking the fail over.I assigned some of the phones to the test CMG but its showing REJECTED as I mentioned in above.
Please review the output below  as you mentioned in the above discussion.
DB Replication
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
DB CLI Status: No other dbreplication CLI is running...
Cluster Replication State: Replication status command started at: 2013-07-08-16-48
     Replication status command COMPLETED 603 tables checked out of 603
     No Errors or Mismatches found.
     Use 'file view activelog cm/trace/dbl/sdi/ReplicationStatus.2013_07_08_16_48_00.out' to see the details
DB Version: ccm9_1_1_10000_11
Repltimeout set to: 300s
PROCESS option set to: 1
Cluster Detailed View from FCMPBX01 (2 Servers):
                                           PING                          CDR Server             REPL.          DBver&           REPL.          REPLICATION SETUP
SERVER-NAME          IP ADDRESS            (msec)          RPC?          (ID) & STATUS           QUEUE          TABLES           LOOP?          (RTMT) & details
FCMPBX01          192.168.30.20          0.053          Yes          (2)  Connected           0            match          Yes            (2) PUB Setup Completed
SCMIPBX02          192.168.30.24          0.732          Yes          (4)  Connected           0            match          Yes            (2) Setup Completed
Publisher Eth0 details
admin:show network eth0
Ethernet 0
DHCP         : disabled           Status     : up
IP Address   : 192.168.30.20      IP Mask    : 255.255.255.000
Link Detected: yes                Mode       : Auto disabled, Full, 1000 Mbits/s
Duplicate IP : no
DNS
Not configured.
Gateway      : 192.168.30.1 on Ethernet 0
Subscriber Eth0 Details
admin:show network eth0 detail
Ethernet 0
IP Address   : 192.168.30.24      IP Mask    : 255.255.255.000
Duplicate IP : no
Queue Length : 1000               MTU        : 1500
MAC Address  : 00:0c:29:3e:09:66
RX stats:
  bytes   :    300438117   packets :      2427004   errors :            0
  dropped :            0   overrun :            0   mcast  :            0
TX stats:
  bytes   :    611806955   packets :      2537790   errors :            0
  dropped :            0   carrier :            0   colsns :            0
DNS
Not configured.
Nithin Louis.
VIP Purple
Hi Nithin,
U need to run Call Manager service on Sub as well.
regds,
aman
Hi Aman,
The Call Manager service running both the nodes.
I have gave the hostname for the server system--->Sever...
Is that the problem?Because I didnt mention the DNS information while the installation of PUb and SUB .If need to change how we can change the hostname to Ip address?
Thanks & Regards
VIP Purple
Hi Nithin,
Simply try changing the hostname to IP address in Publisher first and reboot it since u have no DNS server in setup?
regds,
aman
In the phone i can see that only the call manger 1 is active (Publisher) there is no information in the secondar call manager.
How I can add this information to this.
Already restarted the TFTP service on both the nodes and reset the phones.but the result is same.
We already mentioned in our DHCP server both publisher and subscriber as primary and secondary option 150.
Nithin Louis.
VIP Purple
Hi Nithin,
You cannot add call manager in IP phones.u can add tftp ip addresses.
Can u share the dhcp config ?
regds,
aman
We are using windows server as the DHCP server and in the switches we mentioned the ip helper address.
we mentioned the primary option 150 as the Publisher and secondary option 150 as the subscriber.
Thanks & Regards
Nithin Louis.
Nithin Louis.
if the ip address is still reflecting for the rejecetd phones in the cucm page, can you please check where it is trying to register in the network configuration?
security by default is enabled or disabled?
//Suresh Please rate all the useful posts.
Is auto-registration enabled on subscriber?
Make sure that starting and ending DN range is same in both i.e. publisher & susbscriber with auto-registration enabled on both again.
Then reset the phone and check by taking detailed trace in RTMT.
Also please share the snapshot of DBreplication status from RTMT.
Please check if subscriber is recheable from DHCP server and vice versa.
Regards, Nishant Savalia
Hi Nishant,
Thanks for  your reply.
We are not using auto registeration for both the nodes now.
Please review the attached screen shot for DB replication.
Nithin Louis.
VIP Purple
Hi Nithin,
regds,
aman
Hi Aman,
I tried to register one CIPC with the Subscriber and gave the IP address for Subscriber manually to the CIPC and gave the TEST CMG (subscriber is upper than Publisher)
Its registered with subscriber.and I tried with another 6945 phone manually gave the Subscriber address and assign the TEST CMG.Its also registered.But in the 2 registered phones with subscriber do not showing the reduntant server(Call Manager 2) Ip address(Publisher).
We gave the windows server as the DHCP and is mentioned the secondary TFTP option 150 as Subscriber.I can see the phones which is registered in Publisher as TFTP server 1 (publisher Ip address) and TFTP server 2 (subscriber ip address).
Where I missed the configuration....
Please help
regards
Nithin Louis.
VIP Purple
Hi Nithin,
Can u share what all u have configured in Windows server for DHCP?
regds,
aman
Hi Aman,
We created 3 scopes in the windows DHCP server.The scopes are starting from 192.168.30.x,192.168.31.x,192.168.32.x.
For example if we consider the scope for 192.168.30.x.
Excluded IP address are 192.168.30.1 to 192.168.30.25
Starting IP address 192.168.30.1  and ending ip addess 192.168.30.225
Default Gateway 192.168.30.1
TFTP server 1 option 150 192.168.30.20
TFTP server 2 option 150 192.168.30.24
we followed the following document for configuring the Windows DHCP.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800942f4.shtml
Thanks & Regards
Nithin Louis.
VIP Purple
Hi Nithin,
Try doing packet capture by making DHCP enable on phones
https://supportforums.cisco.com/docs/DOC-11599
what is the firmware of ip phones?
regds,
aman
HI Aman,
I restart the publisher from CLi after that  all the SCCP phones are registered in Subscriber but 8961 phnes are not registering.
Now all the phones are in default device pool and publisher is upper than subscriber....
8961 phones are registering when the publisher came up.I have done factory reset for one 8961 phone but no luck.
Thanks & Regards
Nithin Louis.
Ok..What about the recheability from DHCP server to subscrber and vice versa?
If recheability is fine then please try below procedure:-
1). Stop the publisher services.
2). Stop the subscriber services.
3). Activate the publisher services
4). Activate the subscriber services.
Please maintain the sequence. And if the activity is service affecting then please perform it in low busy hour (night).
Also please try to capture registration process through wireshark and RTMT both.
Any update guys....?
Nithin
Do you have the CM Group defined so that the Device pool with the phones is served by both your Pub and Sub?
-Luke
Hi Luke,
I have default Call mager group in that Publisher is upper than Subscriberand assigned to default device pool and all the phones are registered in the default device pool.
As i mentioned earlier restart the publisher from CLi after that  all the SCCP phones are registered in Subscriber but 8961 SIP phnes are not registering.
Thanks & Regards
Nithin Louis.
Hi Luke,
I have renamed the hostaname to Ip address in the Enterprise parameter and it working fine.
Nithin Louis.
VIP Purple
Hi  Nithin,
thanks for rating.
regds,
aman
1071
