IP Phone Rejected Registration
I tried to upgrade to the latest SCCP firmware of 6921, which is 9.2.2.6 I think. It works fine but when I try to return it back to SIP 9.1.1.3zz, it suddenly got a rejected status and can't even register. I even try to upgrade to the latest SIP firmware which is 9.2.2.7 I think but still got a rejected regisration status.
May I know what are the possible reasons for this? I already tried to set the firmware in device defaults, even tried to restart the tftp service, and add the 69xx.load name under a single 6921 device but still rejected status
you are trying to register with CUCM or CUCME.
with CUCM 8.6 to be exact
did you find a solution ?
Bronze
Re: IP Phone Rejected Registration
     See if you can download the firmware using tftp as in the below link,
https://supportforums.cisco.com/thread/2099511
Please rate if this helps
Try to do factory reset and use Kaja's link for files.
you can use following link to upgrade firmware without CUCM, just put all the files in TFTP server.
https://supportforums.cisco.com/docs/DOC-23730
Hope this helps you.
VIP Purple
Do u have enough license on Call Manager ?
Are u doing Auto-registration or manually adding phone?
regds,
aman
Already solved this, what I did was set something in the common device profile, then phone begin to load tftp from the cucm
can you be more specific "something" ?!
thanks
I'm sorry, I forgot what I set, since I'm on vacation right now, I will get back to you by monday to look into my lab what I set in common device profile
891
