Community Member
IP Phone restart during OSPF convergation
Hi all,
Between Head office and Branch we have two VPN tunnels: main and backup. As IGP we are using OSPF. When I shut down main VPN tunnel, OSPF installs routes through backup VPN which takes aproximately 2-3 seconds. During that time IP Phones (Alcatel-Lucent) are restarting and we lose phone connection ~1minute.
So what to do, that IP Phones stay connected?
1 ACCEPTED SOLUTION
Green
Hi, You will need to
You will need to investigate if you can adjust the ip phone keep-a-live
time between your IP phone server & the ip phones.
Sounds like the timer is set at around 3 seconds if you could increase that to 10 seconds
that will give ospf time to converge.
Hope this helps
Alex
Regards, Alex. Please rate useful posts.
Green
Hope this helps
Alex
Community Member
Thank you acampbell  for
Thank you acampbell  for reply.
Dear minkdennis, while OSPF is converging down time will be 3 seconds, but not ~1 minute, when ip phone restarts.
VIP Red
Even if you were to keep the
Even if you were to keep the phones registered by changing the keep alive, that would still mean that while your routing protocol is converging, you cannot use your phones because signalling is impossible.
Please remember to rate useful posts, by clicking on the stars below.
54
