08-05-2014 08:54 PM - edited 03-16-2019 11:38 PM
Dear all,
Can I Block Outgoing call facilities same shared line for some users.
example : I have two phones A &B .MAnager phone is A and Secretaries Phone is B.They are using common shared line 1000.
this line have international calling facility(partition).I have to block Secretaries international calling.
Thanks &Regards
Ajay Jose K
08-05-2014 08:58 PM
No, you cannot.
08-05-2014 09:20 PM
Dear Jaime,
Thank you for your reply.
Have any other options ?
Ajay Jose K
08-05-2014 10:23 PM
Hi Ajay
As Mr/Jamie said you are unable to do that. You can do one thing , i know may be not good solution but i think can help you. You can use FAC "force authentication code" this code will allow only people who has the code to dial international calls , but this is only apply for route pattern , so all users who need to dial international calls has to type FAC code then international number . So the manager if he has a FAC code he will be able to dial international calls , however secretary if he or she did not have so won,t be able to dial international calls. Kindly find the below link if this ok for you
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/81541-fac-config-ex.html
thanks
please rate all useful information
08-05-2014 10:57 PM
Thanks Ajay and Islam.kamal
I also searching for the same problem. The only solution i think so is the FAC Code. those knows it only call NATIONAL and INTERNATIONAL.
Best Regards,
SHABEER MOHAMED
08-06-2014 12:05 AM
How about using Device CSS? Will that work? I will try it when i am at the office.
