IP Phone show different time
I have CUCM 8.5.1 and confiured NTP server, All phones are showing correct time as per NTP but one or two phone 7942 show GMT time instead of local time. what could be the reason, please help.
  • IP Telephony
Hall of Fame Super Silver
Does that phone have the same device pool applied to them or perhaps different device pool referencing default time/date group?
Chris
This phone does have same device pool as other phones.
Check also the firmware version of the phone
Blue
Did it happened after Day Light Saving started in USA  Sunday, March 11th
or it is happening from day one of the implementation of the phone.
regards
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
we are in kuwait so no matter of day-light saving.
Blue
Is problem has occured recently or is there since the phone were added in CUCM.
You may want to upgrade firmware on the phone to get the correct time.
Ronak patel
Re: IP Phone show different time
Phone model is 7942 and firmware is SCCP42.9-1-1SR1S and even i cannot see corporate directory on this perticular phone it says host not found.
It looks as the phone has booted with an old configuration. Are these two phones on the same ip network as the phones that show right time? Check that they have option 150 set on their netwotk, do they have the right tftp set if you look on the phone?
Yes they all are on same subnet and also other configuration like tftp and option 150 are ok.
1087
