12-01-2011 07:15 AM - edited 03-16-2019 08:20 AM
Hi All,
I am running into an issue at a customer. We recently upgraded to 8.6.2 using firmware firmware 9-2-1S
When some users call between phones at their site the phone will ring but as soon as you answer it you get a busy signal.
if we reset the phone it goes back to working. its not all phones. it seems to be random at the moment.
during the same period you can call those phones from a phone at another site and it works just fine
any suggestions?
12-01-2011 09:23 AM
Hello
Do you check the device pools and relation between the regions?
regards
Sajeel
12-01-2011 10:04 AM
i did the following things and hopefully it cleared up everything
there was only 1 region, the default one. So i created a new region and made sure the codec was the g711 option.
i then updated all device pools to use that region.
I also made sure each device pool had a media resource list assigned to it.
I rebooted all servers also
so we'll see if that clears it up.
