IP Phone unable to get IP Address
     i am encountering a weird situation . bunch of IP phones are not getting IP address from DHCP server phone model is 7906. there are bunch of ip phones having the same problem. i tried so many different things but could not solve the issue. DHCP is working fine, ports are OK. DHCP is configured on publisher and we are using CUCM 6.1 version
please suggest advice Thanks...
Silver
Try to do an erase config from the phone.
JH
Thks JH for your reply
we have another isolated IP telephony setup these phones are working fine there when i bring these phones on my work place they start giving message configuring IP and stuck. when i try to upgrade also get stuck on updating..
Silver
The DHCP service is started on the CM?
If possible (for testing) make an IOS DHCP server, this gives you good DHCP debugs.
JH
Hall of Fame Super Silver
Re: IP Phone unable to get IP Address
Are the phones not getting IP addresses or not registering with cucm?
we have another isolated IP Telephony setup these phone work fine over there but when i bring them at my site they start giving problem on configuring IP address when i try to update them they also get stuck on updating
other phones are working under same vlan same DHCP same phone same phone model same cucm but there are bunch of phones creating problems
are they getting IPs but not registering?
getting stuck on IP CONFIGURING MESSAGE
The Cisco IP Phone is receiving the DHCP server address?
The Cisco IP Phone is receiving the IP address, subnet mask or default router address?
The Cisco IP Phone is receiving the TFTP server ?
The Cisco IP Phone is receiving the correct Cisco CallManager addresses?
Tks
tell me which key combination should i use to enter and check the configuration while its booting.  phones get stuck on configuring IP address message.phone model is 7906
When the Ip Phone show the msg configuring IP add, hit the menu button, and going to network config to see the network config of your phone
1108
