09-11-2017 09:55 PM - edited 03-17-2019 11:09 AM
I am using cisco ip phone 8845 model and 7821 model. how can end users set password(lock) to their ip phones.? please help
regards,
sonam
Solved! Go to Solution.
09-11-2017 10:51 PM
This isn't doable in cisco phone. What you can use is extension mobility to login/logout of the profile. You can set timeouts and auto-logout for this feature as well.
09-11-2017 10:37 PM
this is not possible
YOU COULD use extension mobility to sort of do it, but its nothing like a lock pin on a mobile
09-11-2017 10:51 PM
