IP Phones and Routing
m.metwally
Dears,
is it possible to connect IP phones over 2 routed sites (L3 2 connected sites throughou routers ) instead of switched ones ( connected thru switches L2 trunked )
if possible, what conig. should be added to the router or the 2 switches on both sides?
paolo bevilacqua
Of course it is possible.
Are you the end-user or do you own any certification or equivalent networking experience ?
yes
I'm a CCNA but I'm newbie to the VOIP
VoIP is not anything special. All normal routing rules apply.
