Community Member
IP phones licences
Hi to everyone,
I have a CCM 5.1.3.
We did a bad planning about the total of phones for our office and now we have an excess of licenses loaded in our CM.
The question is, can I download a number of licenses of my CM and use them in another CCM for another office within our company?
If so, How can I do it?
Many thanks for your help.
1 ACCEPTED SOLUTION
Re: IP phones licences
You'll have to call TAC so they can delete the license files and then reach licensing@cisco.com as they'll have to be rehosted.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Community Member
Hi javalenc,
Good response.
I´m going to open a Cisco TAC to do it.
Thanks a lot.
Pablo.
251
