IP Phones Licensing
we know that an 7912 use 3 licenses. If I purchase 100 x 7912G ip phones, how many licenses LIC-CM-XXX= need I purchase
If I purchase an VG224 gateway , need I purchase aditiona licenses?
Hall of Fame Super Silver
Re: IP Phones Licensing
You will need 300 device license units, so 3 x LIC-CM-DL-100= will do it.
You do not need any additional licenses for VG224 GW.
HTH,
Chris
To add to what Chris mentioned above, please refer to this FAQ for future questions on CM5.x licensing model.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item0900aecd805009fc.shtml
That means if need purchase for example 2 vg248 or vg224 I dont need purchase licences... right?.
OK.
if I have the following:
LIC-CM5.1-7825=
LIC-CM-DL-100= (x 3)
Which is the difference between
CP-7912G-CH1
and
CP-7912G=
Which part number need I order to complete
the 300 licenses?.
300 x CP-7912G-CH1
or
100 x CP-7912G=
Where I wrong?..
thanks
Hall of Fame Super Red
Hi Rafael,
Just thought that I should let you know that the 7912G has been announced as "End of Sale" "End of Life" see attached.
EoS and EoL for Cisco Unified IP Phone 7912G
http://www.cisco.com/en/US/products/hw/phones/ps379/prod_eol_notice0900aecd80538042.html
You probably want to go with another model like the 7911G, which is the Cisco recommended replacement model.
http://www.cisco.com/en/US/products/ps6565/index.html
As far as ordering/Licensing goes why don't you fire off an email to;
licensing@cisco.com
I'm sure they will set this straight.
Hope this helps!
Rob
Rafael,
Just like Rob suggested, it would be wise to go for a 7911. Whether you choose to go one or the other, 7912 and 7911, both require only 3 DLUs per phone. So you will need either,
a. LIC-CM-DL-100 * 3
b. CP-7912G * 100
or
a. LIC-CM-DL-100 *3
b. CP-7911G * 100.
Sankar.
457
