10-26-2010 01:25 AM - edited 03-16-2019 01:32 AM
Hello!
I experience problems with localization of IP phones 7900 series on CME 7.1.
Initially installed phones accepted new locale without problems, phones I've added afterwards didn't accept necessary locale.
Below I've mentioned problem phones MAC addresses:
7911G - SEP1C17D3416EB7 SCCP11.8-4-2S SCCP11.8-4-2S Initialized
7906 G - SEP00270D3EEF1F SCCP11.8-4-2S TCP-timeout
7911 G - SEP1C17D3416865 SCCP11.8-4-2S SCCP11.8-4-2S Initialized
See attached part of config.
Pavel
10-27-2010 03:22 AM
anyone???
10-27-2010 04:44 AM
Have you tried by creating Phone specific locales for any of these 3 phones? And, are they SIP phone as SIP phone does not support locales in CME?
And also, please use "Locale Installer" which is a new feature in CME7.1 if you have not used.
Regards..
-Ashok.
10-27-2010 06:13 AM
Regards..
-Ashok.
Specific phone locales are not needed and should not be configured.
The phones are SCCP not SIP as clearly indicated in first post.
Just FYI, the "local installer" creates invalid configuration and doesn't work.
I would do a factory reset on the phones, then observe "debug tftp events" with "terminal monitor".
10-27-2010 10:35 PM
Thanks Paolo,
I will do these steps and revert with debug log.
Pavel
10-27-2010 10:57 PM
Hi Paolo,
Though it's not recommended to use phone specific locales, I have asked for only troubleshooting purposes.
Local installer creates invalid configuration : Does it mean a bug with Cisco local installer or need to customize the given configuration by Local installer? Cisco states this installer is simplified version instead of entering 16 manual steps.
Regards...
-Ashok.
10-28-2010 04:00 AM
As mentioned above, the locale installer is broken, and configuration must be done manually anyway.
11-02-2010 05:32 AM
Paulo,
attached there are two files:
#1. I did a factory reset on the phone and then observed "debug tftp events" as you've recommended.
#2. To let you see what phones are trying to load after usual reset, I've made for the phone which has necessary locale loaded and the other one for the phone which was restarted again after factory reset.
Hope to hear your soonest comments.
Pavel
11-02-2010 05:56 AM
Have you configured type under ephone ?
Please do not use attachments for short logs.
11-02-2010 06:24 AM
Please have a look:
ephone 13
device-security-mode none
mac-address 0027.0D3E.EF1F
max-calls-per-button 3
busy-trigger-per-button 1
type 7906
button 1:13
ephone 6
mac-address 001F.CA35.2132
type 7911
button 1:6
11-03-2010 05:12 AM
any ideas what could be wrong here?
11-03-2010 05:30 AM
Try the hard reset sequence. Yon can find it by searching here.
Also post
show telephony-service tftp-bindings
and
more
11-29-2010 12:57 AM
Hello!
Hard reset didn't help, please see belowshow telephony-service tftp-bindings:
gws1#show telephony-service tftp-bindings
12-01-2010 02:43 AM
Paulo, please check telephony-service tftp-bindings.
Thank you!
