IP phones Migrating from CM5 to CM8 Cluster
Balaji Rao J
Hi There,
I need a help/advise.
We are planning to migrate the ip phones from CM5 (5.1.2.3000-2) cluster to CM8 (8.0.3.24047-1). since CM5 is end of support we are planning to merge the remote site with global Cluster which is CM8.
I wonder about the Firmware Version changes on the IP Phones (7911,7912,7960, 7961 and 7936) and also not sure do i need to do anything on the CTL files on the phones.
Appreciated your feedback and advise.
Balaji
9 Replies 9
ronpatel
Level 8
Level 8
1) when you upgreade your CUCM, The firmware gets change in CUCM which will inturn change the firmware of Ip Phone.
2) Yes you will have to delete CTL file in all the ip phone to make them register to new cluster.
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak,
We are going to change the phone registration from CM5 to CM8, both clusters are in different location (country).
Its there any way i can delete the CTL files on all the ip phones remotely..
Balaji
Yes you can do it.  See below link for the details.
https://supportforums.cisco.com/docs/DOC-15799
Ronak Patel
Please rate all helpful posts by clicking stars below the answer.
If you are migrating from 5.x to 8.x, you don't need to delete any ITLs as the ITL did not exist in 5.x. The phones will simply register to 8.x normall, and download the ITL from there.
From that point, they will not migrate back to 5.x without having the ITL cleared. You can avoid this if you think you will need to move them back by setting the 'rollback to pre 8.x' service parameter as directed in the manuals http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/8_0_1/secugd/secusbd.html#wp1092162
This should leave all the phones with a blank ITL, so you can do whatever you need to do and when the migration is complete, set the rollback enterprise parameter back to normal as directed in the document I referenced.
Just read this again as I wasn't awake the first time - CTL is a bit different, so assuming you have secured the 5.x cluster, can you not sign the new cluster with the same security keys?
https://supportforums.cisco.com/thread/2153141
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Aaron,
WE are going to migrate from 5.x to 8.x, and not going to fallback unless we find any major issues, Assuming Nil issue.
I need to clarify on the CTL part. do you thing we will have a issue when ip phones moving from 5x to 8.x. Do you think i need to check on the 5.x running on the secure mode or not.  I have done some studies on the cm5 with help of local remote admin and found following changes on the phones FW.
Device   TypeCM5 LoadCM8 Load
7911SCCP11.8-2-2SR2SSCCP11.9-2-1S
7912CP7912080003SCCP070409ACP7912080004SCCP080108A
7936cmterm_7936.3-3-14-0cmterm_7936.3-3-20-0
7960P00308000700P00308010200
7961SCCP41.8-3-2SR1SSCCP41.9-1-1SR1S
Do you think i need to upgrade the CM5 phones with cm8 phone load before the migration.please advise.
Balaji
Hi Ronak,
Let me check the web site and get back to you. Corrently i dont have a much access to the system.after checking the website i will get back to you.
thanks
It sounds like you need to go on a training course or read some Cisco Press books before you do anything.
You need to worry about CTL files IF you are running a secure cluster only. Most people do not.
You need to worry about ITL files if you might need to roll back. I would worry about this, as you don't sound like you know much about CUCM at all.
CUCM includes firmware, and firmware maintenance is done when the phones boot up and connect to a cluster automatically.
Aaron
Hi Aaron,
I knew that Firmware maintenance takes place when the phones boots up, just wondering about theip phone behaviors when its moving from cm5 to cm8.
Hi Balaji,
I'll just add a note to the great tips from my friends Aaron and Ronak (+5 each!)
Some of your phone firmware is too old to move directly to the
versions you listed in the upgrade 8.x build. So you will need to address
them ahead of time. it is always best to upgrade the phone firmware ahead of time
anyways to save the overhead on the night of the upgrade.
7912
- should be OK to upgrade directly
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7905g_7912g/firmware/8_0_4/english/release/notes/7912_804MR.html#wp1146003
7936
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7936/firmware/3_3_20/english/release/notes/7936_3320.html#wp1025106
7940/7960
Firmware Upgrade Issues for SCCP
Note
You  cannot upgrade to firmware release 8.1(2) directly from firmware  release 8.0(10) or an earlier release. You have to upgrade to firmware  release 8.1(1) first, then upgrade from release 8.1(1) to  release 8.1(2).
You are @ 8.0.7 so these notes apply to your build.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/firmware/8_1_2/english/release/notes/796040_812.html#wp1152314
7911
Note For all SCCP firmware upgrades from firmware release versions earlier than 8.3(3) to version 9.2(1) or greater, you must first upgrade your firmware to an intermediate version (8.3(3) - 8.5(2)) then upgrade to 9.2(1).
You are @ 8.2.2 so these notes apply to your build
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/9_2_1/english/release/notes/7900_921.html#wp56881
7961
Note For  all SCCP firmware upgrades from firmware release versions earlier than  8.3(3) to version 8.5(2)SR1 or greater, you must first upgrade your  firmware to version 8.5(2). Once you have upgraded to version 8.5(2),  you can upgrade your IP Phone to version 9.1(1)SR1 or later.
You are @ 8.3.2sr1 so these notes apply to your build
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/9_1_1/english/release/notes/7900_911.html#wp42467
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
