IP PHONES NOT POWERING WITH NM-16ESWP
We have a Cisco2811 with NM-16ESW with PPWR-DCARD-16ESW, the card is working fine with PCs and Servers connected to it, however when we connect the IP Phone, it is unable to powerup the IP Phone. Is there any specific configuration to enable the PoE feature on the NM-16ESWP Module.
Any help in this regard is appreciated...
Sriharshaa Prabhakar
5 Replies 5
Hi Sriharshaa,
Can you paste the show diag output from the router.
>> Sushil
Slot 1:
FastEthernet Port adapter, 17 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
Top Assy. Part Number : 800-15156-02
Board Revision : D0
Deviation Number : 0-0
Fab Version : 03
PCB Serial Number : FOC12040F3P
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Base MAC Address : 001e.4ae6.2bd6
MAC Address block size : 17
Product (FRU) Number : NM-16ESW
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 02 A9 41 01 00 C0 46 03 20 00 3B 34 02
0x10: 42 44 30 80 00 00 00 00 02 03 C1 8B 46 4F 43 31
0x20: 32 30 34 30 46 33 50 03 00 81 00 00 00 00 04 00
0x30: CF 06 00 1E 4A E6 2B D6 43 00 11 CB 88 4E 4D 2D
0x40: 31 36 45 53 57 89 56 30 31 20 FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
16-Port Power Daughter Card
PCB Serial Number : FOC120307FA
Part Number : 73-6610-02
Board Revision : C0
RMA History : 00
Top Assy. Part Number : 65535-16777215-255
CLEI Code : CNSPN10AAA
Product (FRU) Number : PPWR-DCARD-16ESW
0x00: 04 FF 40 02 B3 41 01 00 C1 8B 46 4F 43 31 32 30
0x10: 33 30 37 46 41 82 49 19 D2 02 42 43 30 03 00 81
0x20: 00 00 00 00 04 00 80 00 00 00 00 C0 46 FF FF FF
0x30: FF FF FF C6 8A 43 4E 53 50 4E 31 30 41 41 41 CB
0x40: 90 50 50 57 52 2D 44 43 41 52 44 2D 31 36 45 53
0x50: 57 89 56 30 31 20 FF FF FF FF FF FF FF FF FF FF
GigabitEthernet-0 Daughter Card
PCB Serial Number : FOC12040UZ6
Part Number : 73-6593-02
Board Revision : B0
RMA History : 00
CLEI Code : CNSPP20AAA
Product (FRU) Number : GE-DCARD-ESW
0x00: 04 FF 40 02 B2 41 01 00 C1 8B 46 4F 43 31 32 30
0x10: 34 30 55 5A 36 82 49 19 C1 02 42 42 30 03 00 81
0x30: FF FF FF C6 8A 43 4E 53 50 50 32 30 41 41 41 CB
0x40: 8C 47 45 2D 44 43 41 52 44 2D 45 53 57 89 56 30
0x50: 31 20 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Is this happening with all the IP Phones? What IP Phones are you having?
Check the "show power inline" output.
Hi Team,
I believe the NM-16ESW with PPWR-DCARD-16ESW requires and additional Power Supply PPWR-PS-360W on the Cisco 2800/3800 Series Router to Power up the IP Phones.
Request any of the product experts to confirm the same.
We are unable to Powerup the IP Phones on the 2800 with the NM-16ESW and the PPWR-DCARD-16ESW.
Do "show env" and you will see if you have the PoE PS. It fits inside the roouter as an upgrade instead of the standard one.
