IP phones reseting in remote sites
Nithin V
I`m facing an Issue where IP phones are reseting in certain Remote Locations together, What is the Best way to Diagonise this Problem.
Nithin
Jaime Valencia
You don't mention what you have, so I'll assume it's CUCM 8.X
Start by looking at the applog to see what reason CUCM logged for this.
If they're in a remote site there are good chances this is a connectivity issue and that you're missing keepalives
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
