IP phones with AS5300/AS5350
Is it possible to connect directly my IP phones directly to an AS5300/AS5350 ( having only a switch in between). If so, do I connect them just like i would to an ISR router?
jcaro
Yes you can, and yes treat just like and ISR router.
Insure you are running a voice IOS image.
Ok, thanks.
Will try to configure them for testing:).
Actually that is not possible, AS5xxx does not support CME, so you will need an ISR router or an older 1760 or 2600.
I stand corrected. Interviewp.bevilacqua reply is correct.
AS5xxx does not support CME.
