IP Tel Template
abbas.ali
Is there any template on CCO that can be sent used for a customer. The template will be used to explore what currently customer has in their legacy phone system, and what will be requirments for migrating towards IP Tel. I can generate a template based on my experience, but if Cisco has one already in place then I would rather use Cisco. Thanks !
Brandon Buffin
The IP Readiness Assesment tool can help.
http://tools.cisco.com/Assessments/jsp/welcome.jsp?asmt=VOIP
There are also some useful questionnaires in the following book.
http://www.ciscopress.com/bookstore/product.asp?isbn=1587051575&rl=1
Hope this helps. If so, please rate the post.
Brandon
Rob Huffman
Hi Abbas,
Just to add a note to Brandons good info, there is some excellent info in this doc;
IT Case Study / IP Telephony
Best practices highlighted
Installer checklists provided
From this excellent doc;
http://www.cisco.com/web/about/ciscoitatwork/downloads/ciscoitatwork/pdf/cisco_ip_telephony.pdf
Hope this helps!
Rob
