08-26-2012 01:31 PM - edited 03-16-2019 12:52 PM
dear friends
i have cisco router 2821 configured with ccme 8.x for ip telephony which is connected to cisco lan switch 3750g which is in vlan 230 and another portof router 2821 is connected to core switch 4500series port ,yesterday router 2821 Ram damaged and we replaced ,since then the issue started
ip telephone 7975 is not taking picking ip address and is just showing ipconfiguring on telephone screen .
08-26-2012 04:00 PM
Have you checked the configuration on the 2821 router since the RAM changed that you still have your DHCP configuration. Did you use ip helper address onany interface before? I will start by looking at the config
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
08-27-2012 02:05 PM
hi, please check the above config for ip telphony router,
08-27-2012 04:38 PM
Hi Sarfaraz
Have you changed anything on the Router after the replacement?
Check if these:
- Verify that the TFTP Server is operational and service files, validate the firmware for the IP Phone model in question exists on the TFTP server as well as a specific configuration file for the Phone.
- Configuration file should have the MAC address of the IP Phone in the filename
- Verify that you entered the # create cnf-files command from telephony-service configuration mode to generate the necessary configuration files on the TFTP server.
Can you try connect the "not working Phone " on the port of a " working Phone ".
Please show the output of command "show ephone" and "show flash"
08-31-2012 08:57 AM
no i did not change anything on router,the firmware &config file is same
08-31-2012 09:42 AM
Hi Sarfaraz798
Check if these:
