IP Telephony CME Branch Connectivity
Dear Team,
We have two sites , A in Egypt and B in Saudi
The site are connected through VPN
Site A already have CME ISR.
We will also install a CME ISR in Site B also.
will we able to configure the phones to make calls between the site A and B by just dialing the extn without using PSTN
Hi,Please check the section
Please check the section "A Simple Two-Node Topology with H.323 " of the following CME guide which explains various scenarios of interconnecting two or more CME sites.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/srnd/design/guide/cmesrnd/multcme.html#wp1071359
Manish
Hi manish, should the ISR be
Hi manish,
should the ISR be CME or SRST
Hi Edwin,This documentation
Hi Edwin,
This documentation is specific to CME.
Manish
YES.  It pretty much boils
YES.  It pretty much boils down to creating dial-peers on both CME routers pointing to each other, with  patterns that constitute your internal number ranges.
Please remember to rate useful posts, by clicking on the stars below.
hi dennis,Can you confirm if
hi dennis,
Can you confirm if we use CME in riyadh and CME in Egypt (both sites having CME not SRST license), and both sites are connected together.
Will the user in riyadh will be able to dial an extn in egypt
Yes
Yes
java
if this helps, please rate
www.cisco.com/go/pdi
79
