Community Member
IP Telephony Monitoring Software
Need some feed back. Which of the following is a better IP telephony monitoring software? or if you have used some others, please recommend.
1. Prognosis
2. NetIQ
3. Cisco Unified Operations Manager
Solomon
1 REPLY
Community Member
Re: IP Telephony Monitoring Software
Certainly consider NetIQ, as with its Assessment (both pre- and post-deployment), Management, Diagnostic & Reporting capabilities, it offers a full life-cycle solution for VoIP/UC.  If call-quality is a top priority, monitor it with NetIQ from three different perspectives ... past, real-time AND proactive/synthetic calls.  You can go here for more information: https://www.netiq.com/products/voipmgmt/default.asp.
228
