Community Member
IP to IP calls: Low Volume?
Is there anyway to increase or decrease volume of calls between ip phones on different CMEs? ( CME <-> WAN <-> CME)
We are getting complains that volume is too low...
Thank you,
Met.
1 REPLY
Silver
Re: IP to IP calls: Low Volume?
Lower the volume of calls coming in from the PSTN. In addition to bringing all volumes to equilibrium, this will also reduce the likelihood of echo from the PSTN. Volume on IP Phones should then be saved at a comfortable level for the individual.
130
