IP2IP(CUBE) and transcoding
Hi!
I have the CUBE router recieving h.323 calls from Provider, codec is g729. I need to configure IVR(vxml) support on this router on incoming calls, IVR uses g711alaw codec. How should I configure DSP resources for this task?
I have read about universal transcoding and here is my config:
voice-card 0
no dspfarm
dsp services dspfarm
voice service voip
application
service myclock flash:/100/100.vxml
sccp local FastEthernet0/0
sccp ccm XX.XX.XX.XX identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 10 register MTPXXV000
associate profile 20 register MTPXXVIII
keepalive retries 5
switchback method immediate
dspfarm profile 20 transcode universal
codec g711ulaw
codec g711alaw
codec ilbc
codec g723r63
codec g723r53
codec gsmamr-nb
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 2
associate application SCCP
dspfarm profile 10 transcode
codec g711ulaw
codec g711alaw
codec ilbc
codec g723r63
codec g723r53
codec gsmamr-nb
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 2
telephony-service
sdspfarm units 2
sdspfarm transcode sessions 30
sdspfarm tag 1 MTPXXVIII
sdspfarm tag 2 MTPXXV000
max-ephones 20
max-dn 20
ip source-address XX.XX.XX.XX port 2000
max-conferences 12 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Apr 06 2009 08:48:41
Dial-peers:
voice translation-rule 1
rule 1 /84955555555/ /999/
voice translation-profile 1
translate called 1
dial-peer voice 1 voip
description to_IVR
service myclock
destination-pattern 999
session target ipv4:62.117.78.213
incoming called-number 999
codec g711alaw
dial-peer voice 3 voip
description -=cellular=-
destination-pattern 89167396844
session target ipv4:212.48.128.217
dial-peer voice 2 voip
description incoming_peer
translation-profile incoming 1
incoming called-number 84955555555
PS:CUBE is a cisco 2811 with PVDM2-16.
IOS:c2800nm-advipservicesk9-mz.124-11.XW10.bin
Although DSP profiles are registered, but they are not beeing activated while calls ocure. The calling party hears fast busy.
Re: IP2IP(CUBE) and transcoding
Does 'show sccp' show them as registered?
And are you sure you're running into a codec problem (cause=47) and not some other problem causing fast busy?
-nick
vxml#sh sccp
SCCP Admin State: UP
Gateway IP Address: XX.XX.XX.XX, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: XX.XX.XX.XX, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 1
Trustpoint: N/A
Transcoding Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 62.117.78.213, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 10
Reported Max Streams: 12, Reported Max OOS Streams: 0
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: ilbc, Maximum Packetization Period: 60
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
I faced this transcoding issue and changing IOS to Version 12.4(15)T8 resolve it.
Original IOS version was 12.4.11 T3.
617
