Community Member
IPC Dealer Boards
HI
Does anyone have an information on IPC dealerboards? I am unsure how  these terminals connect to the cisco and PSTN, some seem to use analogue lines direct other seem to have E1 / T1 cards - can you register them on cisco?
thanks for any info- got a task to get a couple working
Community Member
IPC Dealer Boards
This will be done by configuring a QSIG trunk between the IPC backend and the Cisco Router hosting the E1 / T1 setup.
For a better solution - why don't you try iptrade dealerboards. They have a much closer integration with cisco callmanager.
http://www.iptrade-networks.com/
Community Member
IPC Dealer Boards
so for the IPC boards you don't really need CM at all, unless I use MGCP to controll the gw
937
