IPC issues
hi
I am running IPC version 2.1.1.0 with CM version 7.1
I am getting the following issues
Mobility key- works but shows ??? on the key
HLOG keys works but displays ??? on the screen when you select it
I have a phone button template with Hold / transfer / Callpark keys on it but they do not display on the IPC - are these supported?
I have a BLF speed dial for another phone and the only indicator I see is in use one , does IPC support DND, CFA and all other indicators?
Dave
1 REPLY
Re: IPC issues
Have you tried another softkey template or make a custom template?
265
