IPC -WLAN &LAN NICs
hi
when i have two NICs on my laptop one for LAN and the other for WLAN for ip communicator what should i configure in device name the MAC of the LAN NIC or the MAC of WLAN
i've tested this when i configure device name of LAN MAC and i connected through MAC it works but if i connect through WLAN NIC it won't work and vice versa
so that i have to configure 2 IP communicators one for LAN NIC and one for WLAN NIC for a total of 6 units for ccm 5.x per each user (laptop)
is there a way to configure one IPC for both WLAN and LAN NICs ??
thanks
Re: IPC -WLAN &LAN NICs
does someone have any ideas
Green
Use "Use this device name" option.
248
