08-15-2008 10:44 PM - edited 03-15-2019 12:39 PM
hi
i got the ipcc 5 seats that came with ccm 6.x, and i want to install this ipcc, my question is that do i need to install this ipcc on an MCS server or any pc will work?
another thing, should i get Win2K server from Cisco or if i have my own Win2K i can use it, in this case how to make this Win2k ready for the ipcc installation?
08-16-2008 06:35 AM
you need an MCS server and the CIPT OS from Cisco
java
if this helps, please rate
08-16-2008 04:27 PM
java thats a good question I want to ask. Is CIPT OS 2003 a purchase from cisco, why doesnt it come with the uccx copy that comes with ccm. seems unsensible to me ;)
Chad
08-17-2008 09:45 AM
i really don't know why the OS is not bundled with the CUCM, but if you already have any CIPT OS 2000 or 2003 that you used in a CCM 4.X version, you can use it as well for the UCCX that you receive
we would need to ask a marketing guy to find out the answer to that =)
java
