Community Member
ipcc and vpn ssl
Have a client that needs to run vpn ssl to push data as a result of datbase data obtains through calls coming into desktop agent. The problem is that once the ssl connection is made to the vpn ssl the ports in use by the ipcc are in the upper range which is not allowed by the vpn. Is there a way around this
218
