Community Member
IPCC Express 5.1
With version 5.1 can you have an agent be associated with two devices? If I am associated with my phone on my desk as an agent can I be associated with a phone at a helpdesk. I want to be able to login as a agent from another phone and receive calls that come into the queue to that phone. Is this at all possible?
Re: IPCC Express 5.1
Hi!
Even on the Release 6.0 SRND we see the following:
"Unified CCX does not monitor or report on activity on the non-ACD extensions on a phone. During the CAD login process, agents supply the designated
ACD extension on their phone. Agents are associated with a specific Unified CM extension (directory number)."
www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_6_0/design/guide/crs60srnd.pdf
So you should associate the agent only to one phone.
HTH!
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
VIP Super Bronze
Sure it's possible if you use Extension Mobility. The requirement of "single line appearance for IPCC Extensions" is not going away. It continues to be present in UCCX 7.0 for example.
If you want to take calls from multiple phones (not simultaneously), configure a User Device Profile and assign the IPCC Extension to that. Note that you'll need to associate the UDP as well as any phones you will be logging in on to the "RMCM" user to ensure proper CTI control occurs.
So you mean Hot Desking? When multiple agents use the same phone with EM, but one at a time? They will use their EM profile, but one phone at a time.
123
