IPCC Express Agent Set Up
Where do you do something with JTAPI for a new user in
IPCC Express. I thought it was on the call manager but could not remember where to find where you do this.
Thank You
Super Bronze
Re: IPCC Express Agent Set Up
When you set up the UCCX system, you set up an 'RM' user. This user is an application user on CCM, and you need to associate the physical handset to this user.
You don't need to do anything in particular for an agent related to JTAPI aside from this.
If you can't remember what your user is called, go to appadmin, then Subsystems/RM and it should be listed on the RmCm Provider section.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
In Call Manager  User Management- Application User - RMCM - Device Info - You have Available Devices which are Devices in CM that have not been assigned to Controlled Devices. When I look in the Available Devices I do not find the MAC of the device I need to move. When I click on Find More Phones and click on Continue to the Website I get an error " Problem with Website security certificate.
Any Suggestions?
Super Bronze
I get that sort of oddity on my Win7/IE8 machine... any chance that's what you are using?
If so, try firefox or something...
Aaron
204
