Community Member
IPCC Express and ANI and DNIS
For a circuit that has ANI and DNIS service, If your telco is only sending you the last four digits of a called number will the full ANI/DNIS show up in IPCC Express? We want to send calls to specific agents based on AREA CODES.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: IPCC Express and ANI and DNIS
Then the calling number is available and usable for all the purposes you can possibly configure.
A PRI circuit or what ?
Community Member
Yes PRI
thanks
178
