IPCC Express - Change IP address
Hi.
I have a IPCCX v 4.5 and i need to change the ip address of this server. Do anyone know how to do this ?
I have tried to do that is specified here.
http://cciev.wordpress.com/2006/06/04/changing-ip-address-registry-settings/
But the service is in partical service. N? agents can connect.
any idees ?
/Soren
Re: IPCC Express - Change IP address
Check the section under Chapter 9, CRS Serviceability Utility from the UCCX admin guide
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/apps_4_5/english/administ/crs451ag.pdf
Thanx for your replay, but unfortionaly, this is not working. The server is comming up in partical in service. I have also done som regedit and still it is not good.
after the regedit i could get the appadmin up, but before ther regedit the server is just booting.
any more good idees ?
have you tried the IPUpdate tool suggested in my earlier post?
If that fails try the following
1. Go to C:\Program Files\Spanlink, and copy the entire folder to a safe location. Delete
the Spanlink folder.
2. Go to Registry, and copy the HKEY_LOCAL_MACHINE\SOFTWARE\Spanlink hive to a safelocation. Delete the Spanlink hive.
3. Re-run CRS setup.
Open a cmd prompt.
Run IPUpdate from C:\Program Files\cisco\desktop_config\util, and update the IP address.
Reboot
241
