IPCC help
I need to look to see if certain calling numbers called in on certain dates. And see who handled the call. Can someone tell me how to do this in IPCC?
1 ACCEPTED SOLUTION
Re: IPCC help
Logon to your publisher server and open query analyzer. Select from the db drop down list CDR
Enter the following:
select * from CallDetailRecord where finalcalledpartynumber='Enter here the specific number dialed' and dateTimeConnect > '1164412800' and dateTimeConnect < '1164585600'
The datetimeconnect is in Julian date format between two specific tims and dates. You can use this to get your Julian date and time:
http://www.minelinks.com/calendar_converter.html
Re: IPCC help
Re: IPCC help
Can you be a little more specific? I don't see the fields you list above when I go into SQL query analyzer.
Chris
Re: IPCC help
I need to search for calls made from a specific number. Not to a specific number.
Re: IPCC help
Yes you can use SQL query analyzer to find your required info from HDS
124
