IPCC MusicOnHold with option to VM
I am developing a script that while the user is queued will ask the user to press 2 at any time to leave a vm.
Music will be then be played and if they press 2 while it is playing they will be sent to vm.
I tried using a menu, but it will play the entire wav file and not hit the user input timeout of 60 seconds.
I also tried using the GetDigits function and it does the same thing..plays the entire prompt.
Anybody have any ideas? I don't want to have to edit the wav file.
Silver
Re: IPCC MusicOnHold with option to VM
I have tried the same but this doesn't work like that. When a prompt is playing you can only interupt it when an agent becomes free.
My solution for a customer was to use several prompts with different lenghts, so after a prompt I can ask " sorry for waiting so long blah blah when you want to leave a message press 9"
My customer was OK with this.
Jan
Hall of Fame Super Silver
You can do this if you use "Play Media" step to play MOH instead of putting the call on Hold/Unhold. This way the prompt (music) will be played from the CRS server instead of using CM MOH and you will be able to collect digits.
HTH,
Chris
I do not see a 'Play Media' step. Do you mean play prompt?
Sorry for late reply, yes that's what I ment.
Chris
119
